fuel injector compatibility
Old Mar 21, 2012 | 05:04 PM
dark scorpion's Avatar
Car: 1990 gta
Engine: 5.7 l 350 v8
Transmission: automatic
I am thinking about purchasing a set of spark plugs from a 94 5.7 camaro and putting them in my 90 gta.
My question is are they compatible with my generation of f-body?
Old Mar 21, 2012 | 05:32 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: fuel injector compatibility
why wouldnt you just get the correct plugs? a 94 5.7 lt-1 with factory aluminum angle plug heads?,.....hmmmm. i doubt it.
Old Mar 21, 2012 | 06:00 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Plugs are so cheap no idea why you would want to buy ones for a different engine
Get the brand and part # and cross reference it against the plugs speced for your car to see if the same
Old Mar 21, 2012 | 06:04 PM
Car: 1990 gta
I totally had a brain fart when I was typing my request.
My question is for the fuel injectors and not the spark plugs.
Sorry guys.
Plugs I have are ok. Delco version.
Old Mar 21, 2012 | 06:38 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
yea, the title of your thread struck my odd. lol. no biggie. id follow the advice above,...cross reference your part numbers.
Old Mar 21, 2012 | 07:32 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Injectors swap fine.
Problem is 94 LT1 injectors are 24lb ;
'90 L98 injectors are 22lb
Old Mar 22, 2012 | 10:27 AM
Car: 1990 gta
Too big a jump to swap to 24lbs?
Old Mar 22, 2012 | 11:32 AM
1985WS6TA's Avatar
Car: 1985 WS6 Trans Am T-Top
Engine: 355 TPI N/A
Transmission: Borg/Warner T-5
Axle/Gears: 3:42
Are your injectors bad? You won't gain any horsepower by just swapping to 24LB injectors, infact you will probably lose horsepower because it will be over fueling the motor a little bit unless you get a tune to compensate.
Old Mar 22, 2012 | 12:08 PM
Car: 1990 gta
Possibly. Sometimes after the car get warmed up it wants to stall out.
Replaced cap, rotor, plugs wires, coil and icm about a month ago.
Fuel pump was replaced 2 months ago.
These are accel injectors my supervisor had left over in a fuel rail from an old engine.
Forget what they are: 21, 22 lbs?
This was done 3 years ago when I got the car.
Old Mar 22, 2012 | 03:48 PM
Car: 1990 gta
So pretty much everything on the ignition system was replaced except the
dizzy itself and the pick-up coil.
Now my people and I have theorized that the icm is bad (i.e. it overheats
and cuts the car off, then it cools down just enough and lets the car run
again).
Could the pick-up coil contribute to this condition before I go throwing parts
at the car it doesn't need?
I plan on getting a gm (delco) icm soon and coat the base with a GOOD
amount of dielectric grease just to be on the safe side.
Any help/suggestions on diagnosis would be appreciated.
Craig
Old Mar 22, 2012 | 04:53 PM
southbay08's Avatar
Old Mar 22, 2012 | 05:01 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
(i.e. it overheats and cuts the car off, then it cools down just enough and lets the car run again).
Well documented and common problem with age
Old Mar 24, 2012 | 05:35 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
thats how my car acted. would start fine then run for a few miles then slowly start dying out. ohm them out hot. thats when they fail. hell let it run in your driveway so you arent stranded. under 14/ ohms can them
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
