external fuel pump ??
Old Mar 25, 2012 | 10:10 AM
kustomiser's Avatar
after hours of reading post and searching for the answer i am looking for i decided to just ask the question. i want to get away from the in tank fuel pump and go to a remote set up. i will most likely leave the fuel cell in the factory location or use a stock tank. i mainly want to remove the pump from the tank for easier access for repairs. in the last 3 years i have replaced the stock fuel pump 4 times and it has gone out again. any help will be greatly appreciated
Old Mar 25, 2012 | 02:34 PM
darrlee's Avatar
Car: 85 IROC
Axle/Gears: 3.42 Std. (3.73 posi, next winter)
Re: external fuel pump ??
What brand of pumps are you using? I want to make sure I don't get that one, Lol
Old Mar 26, 2012 | 12:44 AM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
About a year ago I posted a thread about going to a Holley external fuel pump no interest. I was thinking of making the conecctions in the fuel lines on the car and building the wiring harness to plug into the stock wiring. I would then keep it in the car after testing it, just as a way to get the car home if it quit while we were far from home. I still might.
Old Mar 26, 2012 | 06:49 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
All I can add is don't buy the summit pump. It is very loud!
Old Mar 26, 2012 | 08:31 PM
kustomiser's Avatar
the last pump was from napa not sure who made or rebuilt it. the one before was a delco from the dealer. i talked with the guy i bought the car from three years ago today he told me that in the 7 years he had the car he had put 5 pumps in it.i am thinking that the pumps are not the problem. i keep the last pump that i changed out for some reason. so today i took it and hooked it up to a 12v power supply and it ran. so i then i placed it in a 5 gal bucket with some water and anti freeze for a lubricant and let it run. 3.5 hours latter it was still running. so i put a fuel pressure gauge on it and it blew the rubber hose off at 53lbs.not sure what this means but it may not be bad.i think it may be a power problem now but who knows.
Old Apr 4, 2012 | 01:43 PM
92RSTPI's Avatar
Car: 1992 RS Heritage
Transmission: WC T5
Axle/Gears: 10 bolt, 3.73
Its common for fuel pumps to come "back to life". after failing from worn brushes. After you tap on the pump, they reconnect with the rings on the armature in the motor.
To get a car with a bad pump running, hit the gas tank a few times while cranking and it will usually start and get you home, but don't trust it anymore.
Old Apr 4, 2012 | 02:06 PM
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
so my wife has a 86 trans am 305 tpi well i changed everything cap rotor coil wires plugs pvc so lately its been running like **** it dies. I took all the plugs out today and they r fould out black carbon and wet so would do yall think it is ?
Old Apr 4, 2012 | 06:04 PM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
92firebird305; sounds like a different issue than external fuel pump...
Leaking injectors maybe...probably best to start your own thread, so more people can help.
Hope this helps.
Old Apr 4, 2012 | 06:44 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
That you should start you own new post about your problem instead of hi-jacking this one
seeing you have the completely different problem of TOO much fuel
Old Apr 5, 2012 | 10:24 AM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Before you go and put in a new fuel pump, there is a way to test the one in your tank with out removing it.
Just take a wire and connect it to the G pin in your diagnosic terminal from there run it to the 12 volt acc. in your fues box, when you turn the key to the run possition ou should hear the fuel pump running. And he car should run this way, But This is for only testing or to get the car home in an emergancy situaion.
IF the pump is working look for the problem else where
Old Apr 5, 2012 | 10:50 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
He could just install a racetronix hotwire kit that will bypass the factory harness cause not a good ground will burn up any pump new or used.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
