Multiple Fuel Pump Failure
Car: '91 Z28
Axle/Gears: 10 bolt Posi 3.23
Hey Guys,
Hope someone can help here.
I am having an issue with Killing Fuel Pumps in my '91 Z.
I am now on my 4th Pump since Dec. 2011.
The first pump died didnt think much of it as thecar had sat for about 2yrs and not been run in that time.
But the new pump died within the Same Day just hours after replacing.
And the next 2 pumps lasted a couple months and my 4th pump now seems to be on itslast leg and about to go out again.
I have checked the Harness, as well as the Tank is clean, Fuel Lines are clear, and Filter has been replaced.
I believe the relay is as well working properly.
Also I never let the tank run below 1\4 so the pump is properly cooled.
I am at a total loss as to the root cause of what may be killing the pumps.
Any Ideas wouldbe greatly welcomed.
Engine: 4++,350 & 305 CIs
Re: Multiple Fuel Pump Failure
Sounds like a ground or power wire circuit is causing you some problems.
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Are you sure your pumps are going bad. Or are dead.
How are you checking the pumps ?
How did you check the fuel pump relay. I only know of one way
and thats to take a wire from the fues box 12 volt acc, and run it
to G pin in the diognistc port. if the bump runs then the problem
is a the fuel pump relay or the ground to it.
Car: camaro and gmc sierra
Engine: 5.0 l t.p.i,and 4.3 vortec
Transmission: manuel(iroc)automatic(other)
Axle/Gears: 3.45 bw
I had the same problem on mine, checks your pump with a battery and if it works, your problem is your gauge, the wire on mine was heated and the contact was not good.
Car: '91 Z28
Hey guys thanks for all the advise. After all other checks were completed I finaly found the Fuel Pump Killer.
All the time and money spent it turned out to be only a Bad Gas Cap.
Not able to keep constant system pressure causing the pump to be over worked.
Cap changed and thus far no further issues.
As I lay rubber down to street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride. -Amen
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
