tps voltage discrepancy scanner vs. voltmeter at engine
Old Apr 13, 2012 | 01:42 PM
camarocasanova's Avatar
I recently recent my tps voltage at the tps with a voltmeter, set it to .54 volts. Now my scanner shows it at .47 volts, so the computer is thinking is different. Which one do I trust when setting it, what the computer thinks or the actual voltage reading up front?
Old Apr 13, 2012 | 04:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: tps voltage discrepancy scanner vs. voltmeter at engine
MAF TPI set up? If so set it with the ECM value. That way it is set to what device is using the value.
The difference between .47 V and .54 V isn't that much. And is to be expected when using the two separate devices to read the voltage.
RBob.
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
