GM cam and 1.6 rockers
Old Mar 30, 2012 | 12:13 PM
s10350tpi's Avatar
Hi all, Ive got a 1987 L98 TPI bored .060 over, stock heads and intake. Ive bought a GM oem cam, valve lift .415/.430 D/O @ 0.50 207/213, lobe centerline 116 degrees. ( stock I believe is .404/.415, 202/207, 114.5 degrees ). Im putting in new vortec valve springs,( near stock specs to 1987 L98). Will adding 1.6 roller tip rockers with new cam, can the ECM handle these changes? Thanks.
Old Mar 31, 2012 | 12:47 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: GM cam and 1.6 rockers
If the cam is "computer controlled", yes. Youll be fine. The beauty of MAF systems is that the MAF Sensor has the ability to adjust itself and give you the optimum performance.
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
