surging, stalling, rough idle, running rich.
Old Mar 30, 2012 | 08:42 AM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Well I have all the problems listed above.
I've just spent a year rebuilding this car
I've put a new module, plugs, caps, rotors, it has bosch III injectors, new fuel pump and fuel filter, INtake gaskets, vacuum lines, pretty much everything, the only things that are not new are the tps, iac valve, distributor.
last night I was revving the motor it and the tach was kinda wobbly Makes me believe the distributor is going out.
How do you ohm plug wires?
Old Mar 30, 2012 | 08:44 AM
JJBJR's Avatar
Re: surging, stalling, rough idle, running rich.
How do i make a post??
Old Mar 31, 2012 | 12:49 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Get a voltimeter and set it to ohm. Then connect the ends and note the value.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
jklein337
Sep 19, 2018 06:23 PM
Bradsaundry
Aug 12, 2015 12:34 AM
