Altenator adjustment arm pic
Old Mar 30, 2012 | 07:55 PM
Mackadoches's Avatar
Car: 90 Camaro IROC-Z
Engine: L98 350
Axle/Gears: 3.23 posi
When I took the alternator out, there was a metal bracket that came out with it. I believe it is the adjustment arm and for the life of me I can not figure out how it goes back on, and now my drive belt is loose. Does anyone have a pic of the alternator setup? Thanks
Old Mar 30, 2012 | 07:57 PM
Engine: L98 350
Re: Altenator adjustment arm pic
Or if this vehicle does not use an adjustment arm for the belt, if you could link a pic of the tensioner. Some one told me it was by the ac compressor but i do not see anything like that.
Old Mar 30, 2012 | 08:04 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
if this is a reverse rotation water pump 88-92 tbi/tpi serpentine setup the tensioner is next to the a/c compressor.
Old Mar 30, 2012 | 08:12 PM
Engine: L98 350
So the black cylinder with the looks like 1/2 socket in the middle to the right of the compressor? Awesome man thanks alot.
Old Mar 30, 2012 | 08:25 PM
Engine: Lb9
Transmission: M20
I can't remember if it's 3/8 or 1/2 and this pic has a air pump delete yours will go around the outside of air pump.
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
db057
Sep 4, 2015 07:57 AM
zayne0
Aug 24, 2015 07:22 PM
3rdgenparts
Aug 8, 2015 07:09 PM
