fuel pressure and fuel pump question
Old Mar 30, 2012 | 11:48 PM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Well Ive been having a surging idle problem and some other issues running. Well I checked the fuel pressure and at prime its right about 40 psi (this is with the regulator) and when It starts its a constant 30 psi, sometimes itll go to 38-40 for a mere second but Itll go as low as a 28.
The fuel pump is about 2 years old but hasnt been used in over a year? could it have gone bad?
Old Apr 2, 2012 | 06:54 PM
seawolf18's Avatar
Car: 91 Trans AM
Re: fuel pressure and fuel pump question
Take the vaccum line off the pressure regulator and see if it smells like gas. If it does then the regulator is bad. Factory GM fuel pressure is 43.5 PSI. Hook up the gauge and see if it holds pressure or bleeds down right away. It should hold pressure for hours.
Old Apr 2, 2012 | 09:09 PM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
28's pretty low. id assume a bad fuel pressure regulator. tpi's have them passenger side, near the pressure valve. if i remember correctly you have to take the plenum off to replace it.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
