help me with my TPS?
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
okay so i tested it with an analog volt meter and its confusing me..
when its just at idle, its reading just above the 5 but then as i open up to WOT, it smoothly goes down and stops at WOT right before the 2..have no idea how to read this so is this right?
Engine: 5.7 350 TPI
Re: help me with my TPS?
i attatched the pic..it starts at the black dot and goes down to where the blue ends
Engine: 5.7 350 TPI
oh and i am reading it from the + on the middle and the - on the bottom, as i read
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
There will be a dial on the voltmeter, set it to low volts so you can read it. You will need a scale that goes from 0-12 volts or 0-20 volts or some scale similar to that. At closed throttle, voltage should be .54v. At WOT, it should be over 4v.
Engine: 5.7 350 TPI
ohh i thought i was measuring ohm's -____- my bad..
ill check it tomorrow..appreciate the help dude
ill check it tomorrow..appreciate the help dude Thread
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
MikkoV
Sep 9, 2015 04:25 PM
