Removing TPI runners
hi im guna be installing some slp runners on my trans am maybe this week,but looking at taking the old ones off it looks like i have to remove one of the driver side fuel injectors to get to one of the many bolts thats holding it on...so do i remove the injectors for the runners?...or are the runners bolt on bolt off?
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Re: Removing TPI runners
If i understand your talking about lower torx blots in manifold? injectors should not be in the way. i always got the bottom torx bolts with swivel on my rachet. passenger side normally the hard side.....
Engine: 5.7 l98
runners need to come off to remove plenum and lift fuel rail to remove injectors.......
Car: 91 formula
Engine: 350 tuned port. bolt ons
if you still need help this video my help you GM Corvette TPI L98 Step by Step Injector Swap Video Guide (10 min. video) Better Quality. on youtube.
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
