Bigger maf sensor ?
Old Apr 5, 2012 | 12:47 PM
the Roc-Z28's Avatar
Bigger maf sensor ?
I just got a "first" tpi intake setup and I think that I'm gunna need a larger maf sensor.
Any opinions on what brand or size I should get?
Thanks Very Much,
Alex
Old Apr 5, 2012 | 05:07 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: Bigger maf sensor ?
They don't make a bigger Mass air flow sensor for our cars.
Old Apr 5, 2012 | 07:14 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
How much have you increased engine size by?
Old Apr 5, 2012 | 08:17 PM
It is now a 355 with the "first" tpi intake, lt4 cam, arf 180 aluminum heads, 1.5 roller rockers.
The engine is running rich. and when warmed up wants to stall at stops.
Old Apr 5, 2012 | 08:19 PM
gp90gta's Avatar
Car: 1990 GTA
Yeah you wont need a larger MAF for a 355, a lot of guys here have used the stock MAF with 383's with no problem.
Old Apr 5, 2012 | 08:24 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
& it sounds like you benefit from a custom tune.
Old Apr 5, 2012 | 09:09 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Major changes to engine and stock tune = cr*p running
Old Apr 5, 2012 | 09:21 PM
Car: GTA
MAF will allow you to mod farther away from stock than MAP will, but it looks like you have modded enough to start needing a custom tune. If it was MAP, you'd have needed the custom tune a few mods back.
Might be able to adjust the TPS or (more likely) adjust the idle stop to at least get it to stop dieing at stops.
Old Apr 5, 2012 | 10:28 PM
Awesome. Alrighty, a custom tune is what I'll do then.
Thanks Very Much,
Alex
Old Apr 8, 2012 | 01:40 PM
tequilaboy's Avatar
Posted on behalf of Blowerworks:
blowerworks.net has been providing custom MAF sensors and related tunes for tpi cars for about 4 years now. 3", 3.5" and 4" OD housings are available or whatever size you specify.
Suitable for naturally aspirated, turbo or supercharger use in either blow-through or draw-through configurations. Anything from stock replacement to roughly 1,000 hp can be supported depending upon housing diameter, sensor element, injector and tuning options.
So if you're looking for a bigger maf sensor and custom tune for tpi, here's your source.
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
87hellbird
Sep 14, 2015 05:08 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
