Timing Procedure Question
Old Apr 6, 2012 | 11:43 PM
rickeyhenderson's Avatar
Car: 1985 IROC
Axle/Gears: Wish it had 3.73's...
I've read the "typical" timing procedure, which is 6 degrees advance for a TPI engine. The question I have, is unplugging the ESC module on the firewall the same thing as disconnecting the tan/blk wire from the four wire plug? According to my 1985 GM shop manual, there is a "set timing" connector somewhere on the tan/blk wire, but I can't see it. Seems like my only option is to cut it, as I'm not too confident the four wire plug will stay in one piece if I try to take it apart.
I think my driveability issues are related to my base timing, which is where I'm starting. Any observations would be a huge help.
The car is a 1985 IROC with TPI, recently converted from an automatic to a manual transmission.
Thanks.
Old Apr 7, 2012 | 11:33 AM
Vader's Avatar
Re: Timing Procedure Question
Look here:
Old Apr 7, 2012 | 12:13 PM
Car: 1985 IROC
Thank you! I expected it to be placed between the four wire connector and the wiring harness. Obviously wrong!
Old Apr 7, 2012 | 09:31 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
after u set timing and tighten hold down bolt,hook back up EST wire then disconnect neg. battery cable to clear the EST code it is going to set.
specialized
Jun 18, 2022 09:26 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
