injector nozzle size
Old Apr 22, 2012 | 09:16 AM
tuned-z's Avatar
please recommend a good injector nozzle size for my application: 1986 iroc, 305ci tpi .030 over , word sr-heads , cam-202/206 dur 403/415 lift, 1.52 rockers, stock tpi intake components, paxton sn92 blower 5-6 lbs boost
Old Apr 22, 2012 | 11:41 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: injector nozzle size
42 pounders with a custom prom made.
Old Apr 23, 2012 | 03:00 PM
tuned-z's Avatar
antoine, it looks like you have twice the engine that i have, maybe i should try 21lb injector?
i have 19lb nozzles in there now, worked fine with stock engine under 6lb boost with 50.5 psi fuel pressure, but now with better heads and cam it i think i need more fuel
looking for a recommendation base on what i have
Old Aug 20, 2013 | 07:08 PM
toronto formula's Avatar
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
I have the same question. Did you ever decide on injector size?
I have a 305 and paxton sn2000 and water meth injection and catback
Old Aug 28, 2013 | 03:56 PM
tuned-z's Avatar
have not replaced injectors yet, still unsure of what is a good size.
currently making repair, crankshaft damper broke off and ruined my cruise weekend. need to upgrade damper to one that wont break, extraact the broken bolt, replace pulleys
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
