TPI is the way to go
Old Apr 24, 2012 | 05:57 AM
91rs1022's Avatar
Car: 89 Camaro RS
Transmission: 5 Speed
Just got my 91 Z28 Camaro converted back to tpi from a carb setup. And I will tell you what a difference. The carb setup was fast, but it's faster now. It pulls hard all the way to 5000 rpm, I'm really happy with the way it turned out.
Oh it's a 350 with a 5 speed. I'm guessing about 325 hp, I'm running 24lb injectors, egr delete, larger cam, 305 heades, headers, and 3" cat free exhaust. I didn't built the motor, so I don't know the specs.
I want to thank everyone that helped me out and that I purchased parts from. You guys made this swap easy.
Old Apr 24, 2012 | 08:04 AM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: TPI is the way to go
Glad u went back to efi im also in the process of going back to tpi i was all about the carb setup at forst but then got sick of it dying out all the time early in the morning choke never worked right, plus the tpi gIves the 350 a sharp cutting New technology look when its in the car
Old Apr 24, 2012 | 09:21 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
How much did it end up setting you back? Im wanting to do a stealth ram swap. The whole intake is only $400 or so for my Vortec heads, same as just the vortec TPI base. But all the rest of the stuff I need just seems like it will nickel and dime me to death.
Old Apr 24, 2012 | 11:51 AM
91rs1022's Avatar
Car: 89 Camaro RS
I had
100 for the complete intake.
65 for 24lb injectors, g1 adapter, wire set
30 for gasket set
45 for snokel air cleaner, egr solenoid ( didn't use ), air cleaner boot
100 for tune-up ( cap, rotor, plugs, paint, thermo stat, hoses )
Programed chip from tunedperformanc for 350 TPI with 5 Speed ( GREAT DEAL )
Total Less than $ 400
Old Apr 24, 2012 | 12:41 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Originally Posted by 91rs1022
I had
30 for gasket set
If your going from tbi you may need a ep241 fuel pump
Old Apr 24, 2012 | 05:09 PM
91rs1022's Avatar
Car: 89 Camaro RS
No the car was an original TPI, so the fuel pump was good. I even left the original harness in, and fixed it. I was using the holley bypass fuel pressure regulator on the carb setup.
I think I'm gonna need to get posi. The tires just spin tooooooo easy now. LOL even with the subframe connectors and adjustable bars.
Old Apr 24, 2012 | 06:44 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Nice to hear but it's the way to go back in 1992. I have both ls1 84 z28 and a tpi 87 gta . It's like night and day. Join the dark side
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
