Fuel Line Check Valve?
Car: 89 Camaro RS
Transmission: 5 Speed
I know that fuel pump is causing my drop in fuel pressure. I ran the pump to 50 psi and clamped the feed line shut and it held the pressure.
I was wondering if I can put a check valve in-line to hold the pressure so it will start a little easier, or if I shouldn't worry about it.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel Line Check Valve?
If your fuel pressure is holding this the supply primed the fpr is in good condition you maybe sucking some are in the pump body or the pulsator with most people bypass with a straight hose when the fuel pump is replaced.
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
