Help with Build
Old May 9, 2012 | 06:21 PM
89GTATtop's Avatar
Help with Build
I currently have the 350 pulled out of my gta. I have a stealthram with 24# injectors, trickflow super 23 195 with the .600 lift springs, comp cams xfi 268 and a 2400-2800 stall. The bottom end is going to be rebuilt and freshened with the stock components as long as they are in good shape. My question is is there anything I am overlooking or forgetting? Will ordering a chip from pcmforless make this driveable? Car already has hooker shortys and full exhaust.
Old May 19, 2012 | 06:35 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Help with Build
Check everything. Plug wires, wires, connectors, plugs, freeze plugs. If the engine is out, make sure that if there are spliced wires, solder them and put heat shrink tubing.
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
