1989 firebird timing help please
Old May 15, 2012 | 10:12 AM
hung4wheeler's Avatar
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
The car is a 89 firebird with a 305 tpi . i just had a new distrubator put in but now the car has problems starting unless i avance the timing alot. and once the car is warmed up and you shut it off it wont start it just turns over
heres a pic of the rotor with the car off its fcacing the drivers door not the #1 clinder. did the guy put the disrtibator in wrong?
Old May 15, 2012 | 12:44 PM
Car: 87z28
Engine: 70 LT1
Re: 1989 firebird timing help please
anybody ?
Old May 15, 2012 | 01:14 PM
86ta-adf's Avatar
Car: 86 Trans Am
Most likely put in wrong
Old May 16, 2012 | 01:55 AM
seawolf18's Avatar
Car: 91 Trans AM
Sounds like you put it in 180 degrees off. Rotate the engine to TDC. If the engine is 180 off, the rotor will be pointing at the firewall. Pull the dist. out and rotate it around so it points at number one. Then retime it with the EST wire unplugged.
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
kyleb24
Aug 15, 2015 08:24 AM
Randomtask2
Aug 13, 2015 01:57 AM
antares57
Aug 6, 2015 07:47 AM
