Oil Temp Guage Install?
Old May 20, 2012 | 01:08 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Ive got an '88 C4 and was trying to hook my autometer digital oil temp guage up. Pretty straight forward directions: one wire to power,ground and dimmer switch. Only thing I have a question about is where to install the sender? What do I have to do to keep my factory oil temp guage?
Old May 20, 2012 | 01:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil Temp Guage Install?
There is no factory oil temp gauge.
Old May 20, 2012 | 01:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
on a c4 there is
Old May 20, 2012 | 03:00 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
When did this turn into a Corvette forum?
Old May 20, 2012 | 03:06 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
didnt think it had to be Corvette specific since its an L98 although I didnt know f-bodies didnt have the oil temp guages from the factory.
Old May 27, 2012 | 12:40 AM
BADCAM70's Avatar
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
Why not make T coupling where you have the oil pressure sending unit,driver side behind the intake,should solve your problem.
Old May 27, 2012 | 01:37 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
what exactly do I use for T coupling?
Old May 27, 2012 | 02:03 PM
Engine: Lb9
Transmission: M20
he was talking about something like this , I believe they are 1/8 npt
http://www.ebay.com/itm/1990-91-CORV...r#ht_500wt_844
Old May 27, 2012 | 04:07 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
you can also get the adapter that will go on top of you oil filter on the eng block. it will have 3 holes 2, to a cooler (block them off) and one for your sending unit. they start off at $20 on ebay.
you can install it nexed time you do your oil, easy easy
Old May 27, 2012 | 05:16 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
several methods/locations can be used for oil temp
sender:
-original C4 location in hole above oil filter
-braze a bung into pan and install sender
-use sender that replaces oil plug-VDO had years ago
-drill and tap hole in oil cooler adaptor hot flow area
-add "T"fitting in hotside oilcooler plumbing.
for mine i used original C4 location(my engine is from
'84 vette)
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
drathaar907
Aug 6, 2015 04:20 PM
