injector pulse problem on 1,3,5,7
Old May 22, 2012 | 07:04 PM
hwytom's Avatar
hi i have a 1985 T.P.I. i am getting noid on 2,4,6,8 on 1,3,5,7 no noid
but i have a hot on both the power and ground wires on the odd number bank and the cooling fan runs , anyone have any similar problems they found a cure to?
Old May 22, 2012 | 07:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: injector pulse problem on 1,3,5,7
sounds like you have a bad injector driver in the 1226870, you might think of upgrading to the 1227165.
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Old May 22, 2012 | 07:24 PM
hwytom's Avatar
i forgot to mention it's in my 85 corvette not my trans am is that the same part #?
Old May 22, 2012 | 07:32 PM
Engine: Lb9
Transmission: M20
The 1226870 was a one year only 1985 corvette and f-body
Old May 22, 2012 | 07:47 PM
hwytom's Avatar
ok so i can upgrade it then to the 1227165 just install or is there other things that need to be done? i just pulled the computer and it looks like it has been changed once before someone painted it black with no markings on it
Old May 22, 2012 | 08:08 PM
Engine: Lb9
Transmission: M20
the 870 has a eprom in it and the chip access cover is on one side. The 165 has a memcal and a center plate on the ecm to acces the memcal. Follow the instructions for the rewiring on the link above. you would need a 1227165 ecm and a memcal fro a 350 automatic 86-87 camaros do not have vats, The 89 programing for the 1227165 I feel is the best.
bryan623
Mar 22, 2021 06:43 PM
Street Lethal
Apr 30, 2019 12:14 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
tmellott89
Aug 16, 2015 02:58 PM
