'85 temp sensor location?
Old Jun 10, 2012 | 02:11 PM
pontiacdog's Avatar
Car: '86 Trans Am
I have an '85 trans am with a TPI engine and whenever I try to start it, the engine chokes on excessive gas and stalls immediately.
I figured I need to change the coolant temperature sensor.
Should be simple enough, but for some reason I can't locate the sensor.
Where is it located? I tried to google for location pics but I didn't find the sensor where it was in the pictures.
Old Jun 10, 2012 | 02:36 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: '85 temp sensor location?
it is in the front of the intake next to the bosch cold start switch gm 15326386
looking at the manifold like this image the left lower is the cold start switch, right of the is the cts and above the cts is the coolant fitting for the heater core/ throttle body coolant
Old Jun 26, 2012 | 11:39 AM
pontiacdog's Avatar
Car: '86 Trans Am
Thanks, I got the sensor replaced... only to realize the connector was broken - not the sensor itself..
But I think I can manage it.
Old Jun 26, 2012 | 11:53 AM
Engine: Lb9
Transmission: M20
delphi 12162193 or acdelco pt169
http://www.mouser.com/Search/Refine....yword=12162193
GTAman
Jul 3, 2024 07:29 PM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
tonys91rs
Sep 2, 2015 07:07 PM
