low fuel pressure need help!!!
Old Jun 17, 2012 | 08:46 PM
89trans am's Avatar
I have an 89 TA with a 5.7 so far i have replaced the injectors and AFPR from southbay i also just replaced the fuel pump. The car runs good except for a little stutter if i floor it from a dead stop wich i am quessing that is from my low fuel pressure. my fuel pressure at prime (just key on) is 32psi-running with vac line off is 32-vac line connected drops to 28 running out of ideas any other thoughts would be great.
Old Jun 17, 2012 | 09:05 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: low fuel pressure need help!!!
If you have a adj fuel regulator.. turn up the PSI until its correct. Did you install a new fuel filter after the new pump was put in??
Old Jun 17, 2012 | 09:59 PM
89trans am's Avatar
I forgot to mention adjusting the regulator makes no difference i had the screw all the way out then all the way back in and there was no change in the pressure.I did change the filter
Old Jun 17, 2012 | 10:38 PM
TTOP350's Avatar
I wondered that, you may have a bad pump or bad regulator.
You did hook the fuel lines back up correctly when you changed the pump??
I'm thinkn they only go on one way tho..
Old Jun 18, 2012 | 07:19 AM
89trans am's Avatar
I am starting to think regulator because my fuel pressure was exactly the same on my old pump as it is on the new one. Correct me if im wrong but i should have some adjustment on the AFPR when i turn the screw???
Old Jun 18, 2012 | 09:17 AM
TTOP350's Avatar
Yes you should. Depending on which one you have there should be a flat metal disc inside and on the top of the reg spring for the screw to push down on.. If thats MIA then you wont have any adjustment..
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
