What and Why.....
Old Jun 19, 2012 | 12:22 PM
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Engine: 1992 5.7L TPI
What and Why.....
1) What is the black nipple comming out of the plenum?
2) Waht are possible causes of the build up in the TB?
a) unknown mileage on motor; L98 350
b) PVC lines are clear, new valve.
c) some smoke on start up
d) good oil pressure, recent change
e) new plugs, old ones looked ok
1) shouldve done comp check, didnt.
f) leaks underneath, havent been able to isolate exactly where.
Motor currently rests in this...
Old Jun 19, 2012 | 03:21 PM
GarvinMJ's Avatar
Re: What and Why.....
The first isn't so much a nipple as a bracket. I grabbed one of those from the junkyard the other day, it's for the spark plug loom to rest on (I was lucky to still have it on mine).
The second is a coolant passageway. If the coolant isn't changed, it will tend to leave gunk in the system.
Old Jun 19, 2012 | 06:22 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Nope, thats not coolant. Thats the top of the Tbody. Its oil residue from the pass side valve cover breather tube and is normal, as long as its not dripping all over.
Old Jun 19, 2012 | 06:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Nope
Coolant passage is underneath the TB
Area under the TOP cover is connected to pass side rocker cover ( port is visible on the left of pic )
when engine has excessive blowby, oil will pass back to the TB as shown
Old Jun 19, 2012 | 06:31 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The first isn't so much a nipple as a bracket. it's for the spark plug loom to rest on
Wrong again
The plastic piece that goes there holds the accel cable and TV cable in correct alignment to the TB linkage
Old Jun 20, 2012 | 01:35 AM
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Excellent illustrations and descriptions vetteoz, thx!!
Old Jun 23, 2012 | 09:18 AM
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Is there a GM part# for that bracket?
Ghettobird52
Feb 16, 2014 11:57 PM
DIGGLER
Mar 1, 2008 09:32 AM
scottland
Apr 7, 2003 12:54 AM
