Fusable link question
Old Jul 8, 2012 | 03:43 PM
Kevin Lee 487's Avatar
Car: 1999 Trans Am Ram Air
Posted this in the electronics section as well, need an answer asap
Would running the fusable link wire directly into the positive battery cable instead of the starter solenoid hurt anything?
I ask because the bolt to unhook all the wires from the starter solenoid is so rusted that the wires turn with the bolt, making it impossible for me to remove it with just a car jack to lift the car.
The end of the wire on the solenoid side is very old and brittle ( This being the 2nd time it has broke ) and there isn't enough of it left for me to even splice the fusable side back to the wire.
I attached a Illustration to try and make things a little more clear.
Old Jul 8, 2012 | 10:20 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Fusable link question
It's fine, it will hurt nothing. The Starter is just used as a distribution point for power since there is a hefty power cable already ran there. As long as the component is receiving the recommended amount of power and protection you are golden!
Old Jul 9, 2012 | 01:22 AM
Thanks, went ahead with it and all is well.
GTAman
Mar 15, 2019 11:40 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
