Engine runs rough after I took my MSD digital 6 out????
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
My MSD digital 6+ took a crap, so I sent it away to get fixed.
I thought I would atleast drive the car while waiting for the ignition box to get fixed.
I looped the box out, so it would run, but now it runs very rough.
I unplugged the EST and the engine runs way better! But the initial timing was at 60 degrees advanced! I did NOT change anything in the dizzy to change the timing.
I have no codes.
So I turned down the timing to 10,(which it was before).
Now the engine won't start, but it will runs with the EST unplugged.
I have a spare ECM and it didn't make a difference
Is there a ESC module?
Would a pick-up in the dizzy do this? (I have a pro-billet MSD dizzy)
I also changed the ignitoin module too
I have no codes.
Engine: 4++,350 & 305 CIs
Re: Engine runs rough after I took my MSD digital 6 out????
Make sure the outer ring on your balancer hasnt spun on the inner hub.
Car: '91 GTA
Engine: 421sbc
What would make the timing go really advanced?
Does the knock sensor do that or is there a timing module?
You'll have to look at a new balancer and compare the crank keyway postion to the outer timing mark.
Car: '91 GTA
Engine: 421sbc
I got a code 33(MAP sensor)
IF I test it the way these guys want
http://www.chevythunder.com/map_code_33.htm
Then I should have a faulty MAP sensor (sensor unplugged with ignition on, I get less than 1 volt.
But, if I test the MAP sensor while it is plugged in, it works fine. 4+ volts, then if I apply vacuum, the voltage goes down.
Car: '91 GTA
Engine: 421sbc
If it was the MAP sensor, would it make it run that bad?
theshackle
Mar 5, 2017 06:37 PM
