Holley 58mm throttle body
Old Jul 8, 2012 | 08:23 PM
nickynick17's Avatar
Car: 1989 Firebird Formula 350
Engine: 350 TPI L98
Axle/Gears: 3.91
Hello everyone,
I was wondering if the Holley 58mm throttle body is worth buying and makes a noticeable difference? I am planning to port and polish the intake plenum and siamese the SLP runners on my stock L98 to increase better airflow, trying to see if doing all this will help increase a little better top end and not lean out around 4,000 RPMs
Any thoughts and or suggestions will be much appreciated
Old Jul 8, 2012 | 11:39 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Holley 58mm throttle body
A stock 48mm TB flows over 750 CFM. The runners and porting is good. I'm wondering if the money would be better spent on the exhaust side.
Old Jul 9, 2012 | 01:55 AM
Engine: 350 TPI L98
Axle/Gears: 3.91
yea the exhaust on mine is already done, I have hooker shorties with their y-pipe that goes into a magnaflow cat into a cat-back system from them as well
Old Jul 9, 2012 | 04:52 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
As the other person said there are better places to spend the money. A set of big tube aftermarket runners, and an aftermarket base and ported plenum will do wonders in making it pull up higher.
Cam would be high on the list to do as well but im not sure how crazy you want to go.
Old Jul 9, 2012 | 07:18 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I went into the 11's with the stock 48mm TB.
Spend your money elsewhere.
I didnt need a 58mm TB till I had alot of mods.
Old Jul 9, 2012 | 07:43 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
x2 on what everyone is saying. also in order for a 58 MM to work and be able to reap the benefits you would have to do some port work
Old Jul 9, 2012 | 12:23 PM
Engine: 350 TPI L98
Axle/Gears: 3.91
ok cool thanks guys for all your help
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Thornburg
Aug 27, 2015 08:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
