injectors not spraying fuel
Old Aug 3, 2012 | 09:37 PM
fromford2chevy's Avatar
I am new to this forum and I know there have been many threads about this topic but I cant seem to find one that fits my problem. I have a 89 camaro 305 tbi and I cant get the injectors to spray. I have installed a new distributor, cap, and rotor, a new fuel pump, fuel filter, fuel pump relay and have checked all known fuses. The car with fire up and then die with the use of starter fluid only, but after it dies the injectors are still dry. I have access to a set of noid lights, but am not exactly sure how they work except the fact that i attach them to the injectors themselves. I also dont know how to check the fuel pressure or test the fuel pressure relay. Injectors use to spray about 8 months ago but car has been sitting. I can hear the fuel pump hum for a couple of seconds when I turn the key on. Any suggestions would be appreciated. Thanks
Old Aug 5, 2012 | 01:16 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: injectors not spraying fuel
https://www.thirdgen.org/forums/tbi/
92camaroJoe
Jul 29, 2023 07:57 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Firechicken86
Aug 12, 2015 10:07 PM
