what other cars use the same iac?
Old Aug 9, 2012 | 07:08 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
im pretty sure its the iac acting up, but wanted to get one from jy just to make sure. i say its the iac bcuz if i shut car off and go in somewhere for a few it want start unless i turn the key on for a few then start it .then its starts and runs fine.
Old Aug 9, 2012 | 09:28 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: what other cars use the same iac?
Originally Posted by bbsr72
im pretty sure its the iac acting up,.....it wont start unless i turn the key on for a few then start it .then its starts and runs fine.
Doubt it
IAC plays no part in startup ; only the engine idle after starting
More investigation needed .
Have you pulled the engine codes to see if anything is showing?
Do you have good fuel pressure?
Are injectors leaking when hot?
Lots of possible things......
Old Aug 12, 2012 | 08:39 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i have to hold it to floor to get it to start. i unplugged iac while it was running and it made no difference at all.
Old Aug 12, 2012 | 03:16 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
iac plays a major part in start up it opens to allow for air to enter to let the engine rev to life .
then it slowely brings it down to idle if you unplug an iac , yes the engine may start but only because it returns to the startup position when the car is turned off.
if you jumper a and b on the aldl connector it fully closes then unplug it and try and start the car lol you will have the problem the OP is talking about
tpi cars can use the TBI iac its not a perfect match up but works ie they are differant part numbers but ive been useing a tbi one on mine for years tbi one was $24 tpi one was $70 a few years back hence i used the tbi one
i have not seen anyother iacs that will work unless you few like swaping a 92-93 lt1 throttle body but you also have to cut an splice connections
Old Aug 13, 2012 | 02:44 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
i have to hold it to floor to get it to start..
Holding pedal to the floor shuts off the injectors ( fuel ) so if it only starts that way your engine is too rich when being cranked over;
possibly old injectors are leaking fuel into engine when it is stopped ?
Old Aug 13, 2012 | 05:05 AM
Car: 1991 camaro RS
the clear flood mood almost never works for one reason or another as i can always start the these cars with a foot to the floor
i honestly have never seen a these cars clear flood mood work tbi and 2 tpi computers in my car its never worked never worked in 3 freinds cars "ie there still is an injector pluse" when your supposed to be in clear flood mode
now my lt1 car will not start with foot to the floor no injector pulse when foots to the floor
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
