1987 L-98 1.6 Rockers
Old Aug 26, 2012 | 05:51 PM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
Heyevery one, I have to have my valve stem seals replaced and was thinking it's a good time to upgrade to 1.6 Roller Rockers. The shop is a local one that does Okay work. My question is how detailed of a job is the rockers? Is there adjustments to be made? If so what? I asked the tech that would be doing the job and he said that all you do is just bolt them on. Is that correct or should I run away?
Thanks for any insight
Old Aug 26, 2012 | 09:14 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: 1987 L-98 1.6 Rockers
Sometimes the pushrod rubs on the bottom of the hole where it comes through the head. That needs to be attended to.
Old Sep 5, 2012 | 08:35 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
You dont just bolt them on you need to set lifter preload on each rocker. Its easy to do and can be done in less than an hr once you get the valve covers off. As said above need to watch the pushrods but i didnt have a problem with mine. Self aligning 1.6's. Do pick up abit of power
Old Sep 5, 2012 | 10:23 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
That means grinding, so how would you ensure that NO metal shavings ended up in the oil? I know you can stuff rags in some areas & maybe run a vacuum at the grinding point while enlarging the pushrod hole/slot, but is there any other way to ensure ALL the shavings come out & not end up in the oil?
Old Sep 18, 2012 | 10:44 PM
watajob's Avatar
Car: 92 T/A 'vert
Yes. Pull the heads.
Old Sep 19, 2012 | 01:07 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Mine fit great with no grinding
David Frans
Oct 31, 2015 08:12 PM
bplessy
Sep 30, 2015 12:14 PM
Gordonr1973
Sep 29, 2015 11:59 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
J. Chris Davis
Sep 28, 2015 11:55 AM
