THIS CAR IS GONNA DRIVE ME NUTS LOL
Car: 1989 Trans Am GTA
Engine: 5.7L 350CI L98
Ok so after finally figurin out the no start problem...the can ran good for a week or two and now I have a whole new batch of problems that is driving me nuts
Okay so first I registered it an took it for a spin and realized it was shifting weird...I go an look it has no fluid as then saw the fluid poured out into my driveway...also while I was driving...the car would shut off when I stopped
Now I replaced the gasket in the tranny pan as well as the filter...and then found it has a torque converter it's a low stall pro torque converter anyway took it for a drive felt better shifting even chirped the tires when the car shifted
But it still stalled when I slowed down to stop an then I noticed the car temp gauge was in the red with the fans on...so I'm so confused and pissed now I just can't get it running right please help!!
Also just saw when I turn the light switch on nothing works no taillights headlights or dash lights FML
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: THIS CAR IS GONNA DRIVE ME NUTS LOL
You are having a couple of minor issues.. Even though it will be tough to do a full diagnosis of your car online... Lets try
1. the overheating issue...
a. Have you ensured that there is coolant in radiator
b. Check that the therostat is working; can be done with a cool engine by removing the radiator cap, ensure antifreeze is at a good level, starting the engine, once it gets warm you wll see it circulating in radiator.. This doesn't mean it is working 100% though..
2. No lights
a. check your fuse block which I doubt is the problem
b. check your fuseable links by the starter. They are located about 6 inches to 1 foot from the starter solenoid.. You can use a multimeter and probe the line.. If you do find a bad one, you can either replace the fusable link or remove it which is what most people do. I don't recommend that though.
2. No lights
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
You may have just have blown the dash fuse ect. When I shut my car down my gauge gets pegged all the way. When I turn the key it comes into the normal range it should be. Fuse blows the needle will read way high in my car even though its fine.
Ghettobird52
Jul 5, 2024 11:18 PM
86IROC112
Aug 17, 2015 02:00 PM
