TPI questions
Old Sep 2, 2012 | 10:58 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
TPI questions
I bought a 91 z28 convertible that had no engine or tranny, it still has the wiring harness and CPU in it. I have for it a 55-86 2 pc RMS crate engine, I also got a Full TPI wiring harness and cpu from a 87 with a 85-86 TPI lower manifold, should i switch the whole system to the 87 MAF or should can i mod the old 85-86 TPI stuff to the speed density system, also which one is the better system?
Old Sep 3, 2012 | 07:53 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TPI questions
Originally Posted by 90 camaro cj
91 z28 it still has the wiring harness and CPU in it.
Intake /engine doesn't care what computer is running it so you can run MAF (85 -89) or SD (90- 92) ECM on any year TPI intake.
Seeing you already have the SD electronics in the car ,simpler and easiest to use that system.
Your early TPI plenum won't have a mount for the SD MAP sensor so you will have to remote mount that like on the TBI cars or get a SD TPI plenum that as the MAP mount
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
