correct injectors in my TPI
Old Sep 26, 2012 | 09:49 PM
samtset's Avatar
I recently swapped a 5.7 longblock under my 5.0 tpi stock setup in my 1985 iroc. I changed to the correct esc, knock sensor and what not, i never put the 5.7 injectors in though, im running the 19lbs. I have a set of good used 5.7 injectors from a 94 LT1, do you think its a bad idea? i THIIINK they are 24lbs?
Old Sep 27, 2012 | 12:19 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: correct injectors in my TPI
22 lbs is stock for a 350 TPI. 24's can be tuned to work.
Steve78LT
Feb 24, 2016 12:15 AM
gta90
Sep 15, 2015 04:00 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
