What timing setting has worked for you, to pass emissions?
Old Oct 8, 2012 | 02:40 PM
Khamaro's Avatar
Car: '91 Z28
Hi Guys, having some trouble passing emissions. Now i've changed the cat, dizzy, plugs, and was still running a little bit rich and just slightly over on hydrocarbons..... so I think I was able to narrow the richness problem to the CTS and replaced that yesterday.
Everything seems to be ok now (as i cannot smell gas), but want to make extra sure i pass this time. Currently timing is set to 6, I have heard and read everywhere to retard timing to pass emissions.
So my question is how far do you guys retard the timing before going for emissions, would 4 do the trick, or go to 2 or 0 even?
cheers,
Old Oct 8, 2012 | 03:01 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: What timing setting has worked for you, to pass emissions?
In CA, they check base timing as part of the visual. If it isn't set to specs = FAIL.
Old Oct 9, 2012 | 12:38 PM
Khamaro's Avatar
Car: '91 Z28
Thanks for the reply paulo, i'm in Vancouver, Canada they don't check the timing up here. Any of the BC guys have any input on the timing. Im sure someone here has retarded timing to pass emissions....anyone?
Old Jun 28, 2013 | 08:15 PM
Khamaro's Avatar
Car: '91 Z28
Bump....EGR also replaced, at timing 6 it was running real good and idles perfect. I went thru emissions at timing set to 0 just in care and just failed on hydrocarbons and CO. Would going any lower than 0 on timing make a difference or would it just be worse? or should i set at 6 and try? Nox is way within limits.
Old Jun 29, 2013 | 03:01 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Stay at six. If it isn't passing at that point then something else is not working properly.
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
jharrison5
Aug 19, 2015 05:53 PM
