Small fuel leak at fuel lines. What does it sound like?
Old Oct 18, 2012 | 10:24 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
Removed the intake manifold and installed it. Now fuel leaks at the bottom line around the actual nut fitting itself. I don't see it coming out around the threads.
This is the male end of the line. The part that screws into the line connected to the rail.
It's not spraying either. Just slowly leaking out around the nut.
Is it a bad fitting? Bad o-ring? It seems fairly tight. It's hard to get something in there and try to turn though
Old Oct 18, 2012 | 10:48 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: Small fuel leak at fuel lines. What does it sound like?
Sounds like an O-ring.
Old Oct 19, 2012 | 12:03 AM
CombustoBird89's Avatar
Car: 1989-TPI-GTA
Engine: 5.7
Axle/Gears: Limited Slip/Stock Gears
Yep, sounds like o-ring moved during tightening or it is damaged...hope u didn't overtighten fitting and strip threads...
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
mustangman65_79
Aug 7, 2015 09:55 PM
