camming my 92 trans am 305
Old Oct 23, 2012 | 02:05 AM
thirdgen_bandit's Avatar
Car: 92 trans am
Engine: 5.0
Transmission: 5 spd
Axle/Gears: stock
ok, so how much would it cost to cam my car and what is a good measurement?
Old Oct 23, 2012 | 04:15 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: camming my 92 trans am 305
What are your goals? It's all about the old adage:
"How fast will it go?"
"How much money you got?"
Old Oct 23, 2012 | 04:21 PM
Car: 92 trans am
Engine: 5.0
Transmission: 5 spd
Axle/Gears: stock
its already got an underdrive pulley system, havnt topped it out yet but ive had it to about 120 and still had plenty to play with..i dont have alot of money to just throw down but im just lookin for a good idea on what to save up
Old Oct 23, 2012 | 10:32 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
There is alot of other stuff you can do before you change a cam.
Headers, exhaust, gears, suspension work, etc.
On your note though, you could buy a cam for $200-$250.
Installation would maybe be $4-500 at a garage (4-6hrs of work)
I put in a cam into my stock 305 a long time ago, I wouldnt do it again.
Old Oct 24, 2012 | 03:53 PM
Car: 92 trans am
Engine: 5.0
Transmission: 5 spd
Axle/Gears: stock
i can install myself..but i do plan on doing more stuff before that i was just curious, tuner and throttle body will most likely be next, besides exhaust, then gears when i get the money for it..for a 305 what gear ratio do you recomend?
Old Oct 24, 2012 | 04:45 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
If you have a car that didn't come with the non-G92 spec cam and gears I would recomend following GM's path and stepping up to 3.42 gears. You probably have 3.08 gears if you have a non-G92 option LB9 with the T-5. That will really wake your car up.
As others have mentioned an aftermarket high flow cat, catback exhaust, and headers will also open up the performance envelope on your car as well.
You can also make your own custom cold air intake set up and install a high flow aftermarket air filter. If you do change the throttle body don't go past 52mm. The stock 48mm throttle body works very well on a mild 305 and since TPI was designed for the 305 in the first place the stock 48mm throttle body is not as much a restriction as it would be on a 350 or larger motor.
I would look into aftermarket boxed lower control arms, panhard bar, torque arm, poly bushings all the way around, and new struts & shocks all the way around for the suspension. These basic mods will only add to what thirdgens really excel at in stock form in the road holding department. You have your choice of springs and other components as well if you choose to down the road.
Depends on what your goals are for the car as well - thats just as important as picking the correct matching compoents for your car as well so that you will be happy with the end result. How many miles do you have on your motor?
Just don't forget to have your car in good running order before you start spending money on speed parts. A car that is out of tune, needs a trans or rear end rebuilt, an engine rebuild, or any other kind of basic operational maintenance is going to give you lack luster results when you start doing performance upgrades.
Old Oct 24, 2012 | 05:02 PM
Car: 92 trans am
Engine: 5.0
Transmission: 5 spd
Axle/Gears: stock
thanks alot, now i have a good idea on what i need to do for now
Old Oct 25, 2012 | 12:21 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
You have a 92 speed density TPI. My advise is that you get the equipment and start learning how to tune before you start throwing parts in. These cars don't compensate for mods as well as MAF cars. You need to learn how to tune even if you are doing something as basic as a full exhaust. Otherwise you will be disappointed with the performance gains from whatever parts you put in.
I have a 91 G92 car similar to yours. I had the engine fully rebuilt with an aftermarket cam and a few other mods. I can tell you that the car felt a little less peppy than stock after the cam swap until I got it tuned and then it really woke up.
Old Oct 25, 2012 | 02:31 PM
Car: 92 trans am
Engine: 5.0
Transmission: 5 spd
Axle/Gears: stock
i agree..i can tune it im just getting estimates on things and opinions so i know what path to go down, it has 90k miles on the stock engine and i dont want to mess that up so im just doing a little here and there, its kind of my driveable project car
Old Oct 25, 2012 | 02:41 PM
yaj15's Avatar
Car: 1988 IROC-Z
Thats good. 90k miles is just warming up so as long as the drivetrain is in good order you are doing right by planning out your mods on a well operating car to begin with.
Old Oct 25, 2012 | 02:51 PM
yaj15's Avatar
Car: 1988 IROC-Z
http://thirdgenfbody.wordpress.com
This is an old magazine article I found on this website. The site is worth checking out. They have a lot of stock and modified thirdgen related articles and they have documented performance gains.
This article shows some performance gains on a 1990 LB9/T-5 IROC-Z with some basic intake, exhaust, and chip modifications.
http://thirdgenfbody.files.wordpress...3/phr-pg52.jpg
http://thirdgenfbody.files.wordpress...3/phr-pg51.jpg
http://thirdgenfbody.files.wordpress...3/phr-pg53.jpg
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
