91 z28 running problem
Old Nov 8, 2012 | 11:41 PM
gearheadshed's Avatar
Car: 83 z28 and 91 z28
Engine: 83 has 355 91 has 305
Transmission: 83/auto 3 speed/ 91/ 5speed
Axle/Gears: 83/moser axles 410 gears 91 factory
I have a 1991 chevy camaro that i just purchased is is a 305 tpi. car sat for three years. it had a bad fuel pump. replaced fuel pump new distributor, plugs wires wouldnt hardly run and threw a map sensor code. replaced map sensor. runs better but idles fine go to take off it wont hardley pull out of its tracks. i cut the cat off didnt change anything. when i go to pull off and get started moving its mis firing really bad all plug wires are in the rite place and timing was set with a gun. im new to tune port any suggestions at all if it was a carb i wouldnt have this problem. any help is very much appreciated
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
