EGR DELETE PROBLEMS/PILL SELECTION
Old Nov 22, 2012 | 04:21 PM
gtamann's Avatar
Car: 91 gta
Axle/Gears: 10bolt 3.23
I HAVE A 91 GTA L98 TPI i remover the upper plenum runners and intake manifold,ported polished and gasket matched all the intake installed (egr delete plate )plugged vacuum lines. i also reset timing 6deg btdc i was informed that just deleting the egr can cause problems due to the ecm controlling the egr so i am now faced with the problem of having my pcm flashed to remove the egr air circuit or buy a (pill/chip) to fix the problem but don't know which chip manufacturer i should go with or which stage it should be any help would be great
Old Nov 22, 2012 | 07:03 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: EGR DELETE PROBLEMS/PILL SELECTION
so i am now faced with the problem of having my pcm flashed or buy a (pill/chip) to fix the problem
Your computer has a removable memcal ( prom ) so it can't be "reflashed" in place like later model cars.
I would drive the car and see if you get a EGR code showing up ;some do and some don't.
In any case it won't have any effect on the engine operation; is just a code saying the computer is not seeing the EGR operating because it is no longer there.
Any of the online mail order tuners car do you a new tune with the EGR deleted but you can also get other things done at the same time for same cost,
VATS delete , change fan operating temps , etc
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
