Dropping Fuel Pressure from 48 to 45. Make a Difference at Idle?
Old Nov 30, 2012 | 07:00 AM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
My car runs really rich during cold open loop idle. Do you think if i scale back the fuel pressure from 48 at idle with vacuum line disconnected to 45 it will make a difference?
Old Nov 30, 2012 | 09:38 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: Dropping Fuel Pressure from 48 to 45. Make a Difference at Idle?
Someone may correct me but I'm pretty sure you should be at 43PSI with vacuum disconnected. And yes just a few lbs will make a difference at idle.
Old Nov 30, 2012 | 09:51 AM
insomniac's Avatar
Engine: 5.7 L98
hmm... the spec on all data reads the following, but it dont say anything for engine idling vacuum line off
FUEL PRESSURE:
Ignition ON Engine OFF ....................................... 40.5 to 47.0 psi
With Regulator Vacuum Applied [1] 3.0 - 10.0 psi Less than Ignition ON Engine OFF
REMARKS:
[1]
May be checked with either of the following methods.
^ With Pressure Regulator Vacuum Line Attached at normal idle speed.
^ Ignition ON Engine OFF with 10 Inches Of Vacuum Applied To The Pressure Regulator.
Old Nov 30, 2012 | 03:10 PM
insomniac's Avatar
Engine: 5.7 L98
well i turn my crane AFPR counter clock wise and no change stays at 48 at idle vacuum line un hooked....
turn it clock wise pressure goes up...
any ideas?
Old Nov 30, 2012 | 08:10 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Typically the stock pressure @ idle is 39 psi ( vac connected ) so what you propose will have no effect on idle fueling
Old Nov 30, 2012 | 10:20 PM
LilSki's Avatar
Car: 85 Trans Am
If your regulator is the stock style with a screw in the top then you may not be able to go any lower.
Either that or there may be a blockage in your return line somewhere.
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Kaweh
Aug 9, 2015 02:54 PM
killer777
Aug 8, 2015 02:47 PM
