Which EGR valve do i need?
Car: 89 trans am GTA
Engine: 355
im so lost. i just recently aquired my 89 T.A. vin 8
i have been slowly replacing just about every sensor just for good measure so i know they are good as of now.
i was planning on redoing the gaskets and replacing some other sensors tomorrow. as well as swapping the egr solenoid over to the 95 caddy version. and figured i should get a new egr while i was at it.
problem is the parts store ordered one and it doesn't match the one on my car. the one i currently have comes up under the 305 tpi. is it possible the PO changed it with the wrong one? he did alot of weird things to this poor car.
i am having rough idling as well as massive fuel consumption would having the wrong egr on cause it? i rarely get a check engine light. hasnt come one and i cant remember what code it was last time ti came on but it was egr related.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Which EGR valve do i need?
Engine: 355
i have already replaced all the injectors and CTS and have checked and adjusted the TPS to the correct setting. the PO had messed with the base idle to keep it running enough to get it home i guess.
he also had one injector that was mismatched and was ALWAYS spraying. that was the first thing i fixed.
i aquired a GM replacement EGR valve. so along with some other goodies going on this week this baby should purr again.
got me a set of comp cams magnum rocker arms. (roller tip) and a full roller timing chain. with a pair of edelbrock runners.
i remember seeing something about using rtv sealant when doing the plenum gaskets. any advice?
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I don't think you'll need to use RTV on the plenum gaskets. But if you feel the need to use it make sure the sealant is O2 sensor safe. It should say so on the package.
Engine: 355
so ran into a PROBLEM....
finally getting the car back together....and well i put the new egr solenoid on and i cant seem to figure out which vaccuum line goes to which port.
im using the 95 caddy solenoid now since the orig one was falling apart and aparently glued together.
Engine: Lb9
Transmission: M20
it doesn't matter witch one goes to witch on the solenoid. the vacuum signal starts at the bottom of the the tb and goes to the solenoid from the solenoid to the egr.
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
