Pickup coil
Old Dec 9, 2012 | 11:29 PM
Formula_383's Avatar
Car: 1989 Formula 350
Pickup coil
Trying to diagnose a bad pickup coil on a 89 formula 350, have seen correct ohm specs to be 500-1500 and 800-1500 ohms, mine tested 780 ohms, but cranking ac volts were low, 0.798 ac volts. from what i could find should be closer to 3.000 volts ac, so would you guys agree the pickup coil is bad? Thanks for looking, and sorry if this is the wrong section.
Old Dec 10, 2012 | 01:19 AM
Re: Pickup coil
And just to add, it has a crank but no start problem. Will start with starting fluid and run great after that. Fuel pressure is good. No SES codes. Dont think its vats since security light goes off like it should, and doesnt come on while running.
Old Dec 10, 2012 | 02:12 AM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Re: Pickup coil
Sounds like a problem with the ignition coil if it will start with starting fluid. It's possible you have shorted windings, and aren't generating full ignition voltage. Do a spark check at one of the plugs while cranking and see what the spark looks like. A nice hot spark should be purplish-white, and easily arc from 1/4" away from a good ground. If the spark is weak, you will have to almost touch ground, and the spark will be yellow.
Old Dec 10, 2012 | 03:29 PM
Re: Pickup coil
It has an Accel super coil, but have heard of people having trouble with accel stuff, I have a couple other coils I can try and see what happens. Thanks for the reply.
Old Dec 10, 2012 | 07:22 PM
Re: Pickup coil
Tryed 2 known good coils and a brand new coil wire with no change.
Old Dec 10, 2012 | 08:17 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: Pickup coil
Ohm your injectors. A couple bad injectors will cause a no start, but will keep running if started on starting fluid.
Old Dec 10, 2012 | 08:24 PM
Re: Pickup coil
Thinking stuck or clogged injector maybe?
I would say intermittent spark module failure, but he should be computer controlled. My setup is large cap 4-pin HEI, and I've had multiple spark module failures. In his case, I don't know if there is another component besides the computer that does the same job as the module.
I still lean towards weak spark, but need more info to diagnose better.
Old Dec 10, 2012 | 08:32 PM
Re: Pickup coil
Injectors ohm check fine. its a small cap external coil hei. MAF car. Like I said no SES lights, has fuel and spark. will start and run perfect after you get it running with starting fluid, put a noid light on every injector and checked fine. Plug wires ohm fine. fuel pressure is fine. Tryed to see if it would start with maf unplugged and still wont.
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Eric-86sc
Sep 28, 2015 11:37 AM
