Harbor Freight Fuel Pressure Tester
Old Dec 18, 2012 | 11:00 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
I found this tool online on their site. It says fits most systems except, GM throttle body systems. I wa slooking @ the Actron tester for GM and one of the fittings picture on the HF tool look similar. Maybe someone has used it before?
I want to tell if I am getting sufficient pressure @ my fuel rail.
Fuel Injection Pump Tester
Old Dec 19, 2012 | 10:25 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Harbor Freight Fuel Pressure Tester
The pressure range is more of a problem than the fitting.
Old Dec 19, 2012 | 10:34 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
http://www.ebay.com/itm/TBI-Throttle...-/260732758647
otc makes one but I think theres uses a quick release the above is a actron 0180-000-1465
You said fuel rail so is this tpi or tbi ? the tpi uses a a/n 4
Old Dec 19, 2012 | 12:01 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
After you buy that gauge and the adapters you might as well bought a gauge that fits without adapters. I bought the one below from ebay and it came with a ton of adapters. I have used it on tons a engines including imports, domestics, and even fuel injected boats. The gauge requires no adapters to fit the TPI fitting and has the pressure release button with 6' of hose. It also came with a pouch to hold everything.
http://www.ebay.com/itm/Actron-Profe...d4ed42&vxp=mtr
Old Dec 19, 2012 | 12:09 PM
Engine: Lb9
Transmission: M20
That's a good deal for that one This post reminded me I have a otc 7626 I should sell.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
