Where to get tank to filter fuel line?
Old Dec 25, 2012 | 08:57 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The flexible part of the fuel line that runs from the tank to the filter is leaking. Does anyone make this part? The dealer says not available and I don't want to make anything up. I would just like a stock hose that was crimped on like the factory did. Thanks
Old Dec 26, 2012 | 08:20 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: Where to get tank to filter fuel line?
I was looking for that same section of fuel line over the summer and couldn't find a NOS or repro part anywhere. Mine was not leaking, but the section of hardline that it was crimped onto had some scary rust on it. I wanted to change it before it became a problem. I ended up buying some AN adapters to hook up a 6AN line in its place. Good luck in your search.
Old Dec 26, 2012 | 11:29 AM
3ZMan's Avatar
I don't know if this is directly applicable in that I haven't had the tank out in my 3rd gen for awhile. When my 4th gen fuel lines had issues I could not get a replacement set of the plastic supply and return lines so I had to make something up. Aeromotive tech support was most helpful, they might be able to suggest the adaptors to use for a third gen tank.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
