wiring single cooling fan tpi
Old Jan 1, 2013 | 11:22 AM
kreator33's Avatar
i have an 86 trans am , i dropped a built 355 tpi in there, with a aluminum 3 row rad, the ecm and wiring is from a 87 iroc, i deleted the a/c, even the heater, only gonna drive in summer when weather is good. now my question,, i dont have dual fans in the car i have the stock 86 single fan, since i dont have a/c , and i deleted half the harness to have only one relay to my fan,,,, now what should i use to trigger that single fan? i have, 1. the stock temp switch on pass head,2.a temp switch on my new rad 3. the ecm that takes the info from that temp switch on the intake below throttle body, can i use the gre/wh wire from the ecm and both switches on the same relay?? should i rely only on ecm? only on 1 switch? 2 switches? if i use the ecm at all,,,, since i have an 87 wiring, do i ground, or open the blue wire from the a/c? cause i dont have a/c ,,,the car i took the ecm and wire from used to have a/c. if i dont use the ecm,, can i just leave it like that or is there something i should change not to mess up anything,,,,,, i just dont wanna try a bunch of things, want to wire the car properly once,, and hide harness with loom once and for all,thanks.sorry for the looooong question
Old Jan 10, 2013 | 10:32 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: wiring single cooling fan tpi
C1 of the 1227165 ecm will control the ground side trigger of your relay. The ecm uses the ect reading and the calibrated temp set in your memcal to turn on the fan usually around 226F. Wiring it this way is better than using a temp sensor that grounds mounted in the head.If your worried about the ecm not grounding the fan relay you can alway wire a second switch in the head and connect to the wire going back to c1 of the ecm.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Sanjay
Aug 12, 2015 03:41 PM
Leggman1
Aug 6, 2015 04:15 AM
