Valve cover orientation....
Car: 1986 K5 Blazer
Engine: 1992 5.7L TPI
...after looking around at different TPI engine bay pics I noticed different valve cover orientations...
Meaning.... on mine, 92' 350, the DS has the oil fill cap up front and the PCV towards the firewall, on the PS the vent tube is up front.
Ive seen several pics where the PCV and oil fill cap are switched up. Could be different years I guess, and I dont see how it would hurt...
...so is there a right/wrong way?
Engine: 4++,350 & 305 CIs
Re: Valve cover orientation....
Depends on the year of the car as to how they are set up. Early TPIs have the oil fill to the rear and newer ( guessing here,90-92?) cars have it close to the front of the motor.
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
My 91 is towards the front for oil fill.
Car: 1986 K5 Blazer
Sounds good guys, thanks for the info....must be something that changed from 89-90...
I "think" it changed around the time the cars went to SD.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
