TPI Accessory Bracket numbers
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Whats up guys. Haven't been on in a while, but I'm about to get my 355 Vortec LT4 Hotcammed full roller back from the machine swap for my V6 to TPI swap, and I need to get the front accessories. I found a guy on craigslist who has the whole set up for $300, but is that a good deal? I found the one bracket for the power steering and alternator on ebay for $96 free shipping, but I still need the others. I was wondering if anyone has or knows the part numbers for the brackets. I plan on running no emissions or smog pump, no A/C. So could I just get away with the power steering and alternator bracket? Thanks for the help guys. Gotta find my build thread and update it with more pictures soon...
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI Accessory Bracket numbers
10055800 - Secondary Air Injector Pump Bracket.
10105212 - Generator & Power Steering Bracket
for the air pump delete There are 2 different styles gm 10186167 with a large 6 grove pulley or gm 10129569 flat idler.
The a/c delete is Dorman 34157 or gm 10055890
$300 sounds high even if it comes with the alt and a/c bracing You might want to talk him down to the $150-$200 range.
Car: 1990 Camaro RS
I was thinking $300 was high too...it comes with the A/C compressor but more than likely its R12 so useless. Also didn't come with bolts, but it did have a harmonic balancer that I could have used since the one that came off the 350 from the 99 Silverado cracked when I removed it.
Found all the parts on Summit though, just under $200 minus tax, but I have a $25 off voucher so all in all about $200 shipped to my house for brand new, versus $300 and the gas in the truck to get there and back.
Engine: 4++,350 & 305 CIs
R12 is waay better than 134a. IMO
Car: 1990 Camaro RS
Well either way R12 or 134a, my car didn't have A/C anyways, I have the C41 standard fan and defrost in my car, not the C60.
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
300 is high tell him 175 or go to a junkyard
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
