Help with fuel injection
Old Jan 9, 2013 | 11:44 AM
Camaromunchkin's Avatar
Ok, so I'm feeling a bit stupid after doing this, I took apart my multiport fuel injection on my stock 1985 camaro to change the seals on the head gaskets. When I went to put it all back together I had forgotten how to put it all back together the way it went. Any help with some pics of the correct way it goes would be most helpful. Thanks guys.
Old Jan 10, 2013 | 08:33 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Help with fuel injection
Welcome to 3rd gen. This board is more for the electronics side of fuel injection. I'll move your post to the TPI board here. You will likely get a better response.
IIRC, someone just recently posted a picture of the TPI set up. If I find it I'll post the link here.
RBob.
Old Jan 10, 2013 | 08:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This thread has a ton of info in it:
https://www.thirdgen.org/forums/tpi/...eck-valve.html
RBob.
Old Jan 10, 2013 | 08:48 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Jan 10, 2013 | 08:52 PM
Thanks guys, very helpful
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
86Base
Aug 13, 2015 05:06 PM
