Passed Smog... on the 3rd try
Old Jan 22, 2013 | 01:07 PM
Marc Maro's Avatar
Car: 1991 Camaro Z28
Engine: 5.7 TPI, Dyno Don Headers
Axle/Gears: Eaton Posi - 3.42
If anyone is having issues with high NOX readings, lower your Main Spark Advance Table (filled mine with all 10s) and you can seriously reduce it. Spent hours chasing EGR issues and catalytic converter issues that weren't the problem... when all I had to do is burn a chip. Hopefully this saves you time.
1st Test
Failed... Modified Headers
HC 15mph 81(MAX)/65
HC 25mph 58(MAX)/44
CO% 15mph .50(MAX)/.13
CO% 25mph .40(MAX)/.09
NOX 15mph 537(MAX)/1279
NOX 25mph 494(MAX)/1179
2nd Test
Pass... Modified Headers (with sticker from SLP)
HC 15mph 81(MAX)/17
HC 25mph 58(MAX)/10
CO% 15mph .50(MAX)/.03
CO% 25mph .40(MAX)/.02
NOX 15mph 537(MAX)/1291
NOX 25mph 494(MAX)/1243
3rd Test
HC 15mph 81(MAX)/54
HC 25mph 58(MAX)/16
CO% 15mph .50(MAX)/.23
CO% 25mph .40(MAX)/.08
NOX 15mph 537(MAX)/433
NOX 25mph 494(MAX)/456
Old Jan 22, 2013 | 02:55 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: Passed Smog... on the 3rd try
Did you notice any performance gain? Probably not.. California emissions are the hardest to pass and cars have crazy parts that are totally different than Federally regulated cars. Good job on passing that test..
Old Jan 23, 2013 | 03:16 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
" California emissions are the hardest to pass and cars have crazy parts that are totally different than Federally regulated cars."
What are some of these 'crazy' parts? I live in California, bought my Z28 in California, I pass emissions tests in California.
Old Jan 24, 2013 | 10:47 AM
ibmtech's Avatar
Car: 1987 IROC-Z
I believe it starts with your ECM.. Maybe I am wrong, but CA emissions is different than any other state. Even when I worked in Autozone, I would have to ask if it is Federal Emisions or California Emissions on alot of cars. I would be interested in knowing what ECM and Prom you are using by number
Old Jan 31, 2013 | 06:04 AM
Slowridr's Avatar
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Solved my high NOX by reducing the timing in the 1000-2000 RPM range in the main spark table. If you can burn a chip, it's pretty easy to do.
from
https://www.thirdgen.org/forums/tpi/...ml#post5477561
Thanks Marc. I have no idea how to burn a chip (have no chip burning equipment either). I need a remedy quickly. I guess I could have someone to burn a chip for me. Any other options on this? By the way how did your car run after that?
Old Feb 10, 2013 | 11:30 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
This is good info. I haven't passed a CA emissions testing since '06.
Old Feb 11, 2013 | 07:43 AM
Slowridr's Avatar
You have not been driving your car since 06'?
In any case I found that my timing was set to 8 BTDC so I dialed it back a little to 6 BTDC and it passed. Try checking your timing and if that's the issue, dial it back some. I know that works for high NOX not sure if it works for anything else.
Old Mar 18, 2013 | 10:56 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Essentially, all you did to the table is this?
Old Mar 18, 2013 | 11:12 PM
Marc Maro's Avatar
that should work, just don't try running with that table on the street. very little power.
Old Mar 19, 2013 | 02:06 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Wouldn't this damage the engine if you ran it like this on the street?
Old Mar 19, 2013 | 02:54 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Thanks. Since I know the RPM range where the 15mph and 25mph tests are run, I shouldn't have to change the entire table.
I don't plan on leaving that chip in the car.
Old Mar 19, 2013 | 10:16 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Far as I know all 50 state cars had the same emissions everything on them.
Ca just regulates its all there more than most
Old Jun 2, 2022 | 02:21 PM
Jbot3k's Avatar
hi, I had a question, I’m getting ready for a smog check in California and I’ve read many different tips including back off the timing a bit so I set mine back from 6 btdc to 8 btdc. From your experience this is opposite. I’m just trying to get any helpful info from other peoples trial and errors to help me if you have any input I’d appreciate it thank you!
88 gta 5.7 L98 auto
Old Jun 7, 2022 | 06:32 PM
newbvetteguy's Avatar
Car: 1979 Corvette L82
Engine: Gen1 SBC 350 L82 4 bolt mains 010
Transmission: Monster 4L60e 2wd 1997 PWM capable
Axle/Gears: 355
88 gta 5.7 L98 auto
I'm definitely interested to see what the CA folks have to say, but my understanding is that anything that decreases max cylinder TEMPERATURE reduces NOX formation.
Reducing ignition advance is one easy way to reduce cylinder pressure/temperature, but there's lots of others.
Adam
91formulaSS
Jun 24, 2008 05:14 PM
robbrobb
May 24, 2006 08:43 PM
chio987
Sep 16, 2004 02:25 PM
PeNZ
Nov 19, 2002 08:32 PM
