1991 camaro wont start
Car: 1991 Camaro Z28
Engine: 5.0 TPI
Transmission: M5
Axle/Gears: 3.08 now 3.42
hi, i have a 1991 camaro z28 sometimes in the morning it crank but wont start after several tries, then the rest of the day start as if nothing happen until the next morning when every thing start again, so if you can help me i will be gratefull. by the way i don`t speek any english so if you can use simple words it will be better
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: 1991 camaro wont start
Try turning the key on/off so you can hear the fuel pump prime a couple times before actually trying to start the engine. See if that helps.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Car: 91 Z28
Engine: L98 TPI
Transmission: 700R4 Transgo 2-3
Axle/Gears: 10 bolt 4.10s
I am having this same problem. I have tried to turn the key on/off a few times before trying to start it and nothing it just cranks. If I go back out later, it will fire right up. I put new plugs, wires, cap and rotor on, no difference. I can hear the fuel pump turning on.
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
