5.7 TPI Injectors Not Getting Enough Voltage???
Car: !989 Camaro IROC-Z28
Engine: 5.7 TPI
Here's the deal, I've replaced the fuel pump & relay, ignition coil & control module, pick up coil, & bypassed the VATS Pass Key System. I know I'm getting fuel up to the fuel rail, & I know I'm getting spark. I checked the voltage on the injectors & when i turn it over its only getting 2-3 volts. What would cause this & hoe do i fix it.
Engine: 4++,350 & 305 CIs
Re: 5.7 TPI Injectors Not Getting Enough Voltage???
Sooo is the car not starting?
Gotta ask, did you check all of the fuses??
Engine: 5.7 TPI
~UPDATE~
Car is running now, turns out the bypass had switches inside that had to be switched if the car didnt run. Running goosd now though.
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
