tpi head question
Old Feb 5, 2013 | 12:50 AM
Dirdyburd's Avatar
Car: 92 z28
tpi head question
hello,
i have a 305 block about to be rebuilt. i have a set of heads, casting numbers block 14010201. heads 14014416. my question is, will a tpi set up match up to these heads?
i have googled this a few times and it keeps sending me to this site which i have been trolling for about a year now. everytime i google this it doesnt really answer my question. is there someone here who can send me to the right thread or that can answer this question?
thank you for everyone's time,
Dirdy
Old Feb 5, 2013 | 01:19 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: tpi head question
Originally Posted by Dirdyburd
heads 14014416.
Helps if you mention year
Any TPI will bolt up fine ;
however depending on the type of the TPI base used ( early vs late , Vette vs F-Body )
you may have to elongate the 4 center bolt holes of the intake base because late F-Body intakes had a different bolt angle on those four bolts compared to the early heads like your '416's.
read
http://www.hotrodlane.cc/Streetstories/choosetpi1.htm
http://www.hotrodlane.cc/Streetstories/choosingtpi2.htm
Old Feb 5, 2013 | 03:23 AM
Dirdyburd's Avatar
Car: 92 z28
my fault on year. according to the block number it says 80-84 305
i appreciate the quick reply. it helps a noob out tremendously.
and on a side note, it is my understanding they now make an intake to fit with vortec heads for tpi?
Old Feb 6, 2013 | 09:04 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
my fault on year.
I meant the year of your car or the TPI intake you plan to use ?
Fill out your profile so we don't have to guess
Any SBC heads ( inc Vortecs ) will fit on any year SBC block ; it is the angle of the intake bolts in the head ( and obviously the TPI intake that came with them ) that vary by year as noted above
https://sdparts.com/index.php?q=deta...-center/sd3816
Old Feb 6, 2013 | 09:54 PM
Dirdyburd's Avatar
Car: 92 z28
my fault vette. i forgot to update my info earlier.
i currently have a 92 z28 with a 305tpi already in it. this car is planned to be worked over last project.
the block in question came out of a early 80s truck. casting numbers says 80-85 year produced. the camaro is in a position that i cannot pull the motor out and make a copy so to speak of it. but this block is already out and a plan to drop it in a 02 s10.
my plan (trial and error) is to build another 305 tpi, bore it .030, tpi set up, and port and polish intake and heads. i have the manual for the conversion for s10. since this motor was already free from a vehicle, i wanted to ask and research any and all i can about tpi. every time i google this, it sends me here. the ipad app isnt much help.
the z28 i have will eventually have the motor yanked in a few years and 350 dropped into it like it deserves to have.
i appreciate your info, vette
Old Feb 7, 2013 | 01:11 AM
Dirdyburd's Avatar
Car: 92 z28
my apologies. i was reading these from my phone and didnt see the links you posted. i realize this build wont be going into my camaro, but every tpi question i look for sends me here. i will do more reading on compatibility soon.
thanks again
Old Apr 18, 2013 | 09:05 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
read
Just wanted to say thanks for the links! I just bought a TPI unit off craigslist and the seller couldn't tell me much about it. Those links let me identify it as an 85-86 TA unit, which means it will bolt right up to the 416 heads on my 350.
MustangBeater20
Oct 29, 2022 09:20 PM
gta90
Sep 15, 2015 04:00 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
