Fuel Rail o-rings
Old Apr 18, 2013 | 09:26 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Fuel Rail o-rings
I am planning on finally replacing my injectors this weekend. I am reading that I need to replace the feed/return lines that supply the fuel rail, and also the o-rings that connect the 2 sides together with the fuel pressure regulator. I also plan on replacing the diaphram this weekend as well (already have), but am confused on which o-ring kit I need to complete the task.
From my reading(s), it appears that I would be best off with the "kit". I have found what appears to be the "kit" @ O'Reilley's and AutoZone, but they don't have it in stock.
BWD - Fuel Injector Seal Kit
This kit appears to be similar in appearance to the AC Delco kit,
ACDelco 217-440 O-Ring ACDelco 217-440 O-Ring
Am I on the right path or do I need to look for something completely different?
I will try the local Chevrolet dealers to see if they may have the AC Delco kit on hand.
Old Apr 18, 2013 | 10:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Fuel Rail o-rings
These are the actual sizes required if you come across a place that has Viton O rings for sale individually
http://webpages.charter.net/khasting...uelsystem.html
Old Apr 18, 2013 | 10:51 PM
Engine: LB9 | LS1
Thank You!!!
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
